Just got out of the stealership trying to figure out my rear whine/rumble strip noise. They said the rear 3rd was toast. New pinion bearing, set of carrier bearings and probably, because of all that wear the rings are bad. Quoted me a repair bill of $2000!!!! No thanks. I will do this with help from my friends at IH8MUD. I really just think it is a bad bearing or two but I am just speculating. Since I have owned it, the gear oil has never gone too low.
A little background, I have already replaced the 4 u-joints and had both the shafts balanced. They did nothing to help with the noise that goes up with speed and down with less speed.
So bad rear 3rd from the dealership. Should I get another opinion?
Options?
1. Buy a good used stock one from Slee. Can a 2.5 banana guy install this?
2. Buy all the bearings, crush sleeve and seals from Dan and have the local shop rebuild it.
3. Upgrade to 4.56 from ringpinion.biz to do front and rear. I will never go to 35s. Is it worth it for 33s?
A couple notes; this is my DD so I cannot be without for an extended period. With a baby due in May and financial obligations I will not be throwing ARB lockers in. I wish I could but not now.
Thanks for all the input guys,
Matt
Options?
Matt
