Realtime help! Bj70 drive axle U joint #
way north of 60
does anyone know what the part number is for an aftermarket ujoint?
does spicer or any of these places make a u joint and if so does anyone have the number handy..
any help would be appreciated.
Jon
is there an aftermarket number that you know of.. my truck is broken and i cant wait for the stealership, i called them and they said it is the same as a 60. The local driveshaft place has never even seen a landcruiser axle...
aftermarket crossreferenced number anyone?
TIA
Jon
mcquay norris U1511
gmb 2200020
I think the nepco's spin in the ends...
fwiw.. if you need to drive it pull the front and install it on the rear.. they are fairly close and should be fine to run on the street. I would only use toyota u joints...
i bit the bullet and bought genuine toyota parts. what happens if i replace just one.. is the other going to pooch soon too?
waiting another day is not an option!
If it was original like the other it could go soon as well. I make it a habit of changing them at the same time when the shaft is off just to save some hassle.
I'm in Ottawa, I have a bunch of relatives in Hamilton.
