REALLY REAL TIME: Removing Aisin Hubs
Cuba, MO
Hey guys i am down at my dad's trying to remove the locking hubs off my 60. I can get the outside part with the "selector" on it off. Then I take the little nuts off from around the hub and the loose washers.
Now what. I try pecking on the cone washers that are surrounding the studs like prescribed but no luck.
I don't have access to a heat source(torch).
If worse comes to worse can I cut the studs off? Will that help.
thanks
lunyou
Do not cut the studs!! That will only cause you more problems. I have found that a 3/8" ratchet extention, 6-8" long, and a medium sized hammer is all you need. Simply place the tip of the extension on the stud containing the cone washer and wack it with the hammer 2-3 times for each washer/stud. I have never seen this method not work.
Good luck
From my own experience and others I've seen on this forum. I took a narrow metal bar, placed it on the cone washer only and 1 to 5 hits with a hammer later... they came loose. Not easy but I haven't seen an easier and cheaper way yet. I did it to a 4Runner and even the Chilton's manual recomends that method.
DON'T CUT ---
Use a BRASS Drift (soft), and place it on the top of the stud, and WHACK it with a 2-3 lb hammer -- Cone washers will release and pop up enough to remove with needle nose or your fingers.
Spraying with PB Blaster, WD40 etc, and letting 'em sit a bit helps.
Mine were super tight - there's a small gap in the cone itself, I tapped as close as possible to that gap with the edge of a cold chisel - couldn't get a brass drift on it enough. You don't want to hit ON the gap, but beside it so the cone flexes into it... If you have a deadblow that wont mar up the hub too bad, a few sharp raps on the outermost edge might prove useful [think leverage on the cones] but be careful with that.
WD40 and patience are your best bet. I struggled with mine for almost 2 hours.
Good luck.
Did you take the snap ring off?
The way I've always done it is to put a socket against the hub flange (outside the cone washers) and rap with a hammer. This way you don't run the risk of damaging the studs.
I use a Medium BFH and a heavy brass drift. Easy.
Did it work?
Thanks, All
I just wanted to say, "Thank You" to all of you who help out with making this information so accessible. I couldn't figure out how to get those cone washers off, and the 3/8" extension and hammer trick (first post on this topic) worked like a charm.
I'm trying to get ahold of a 54mm socket to break the lock nut fo the wheel bearings loose, but not having much luck.
Anyway, thanks guys!
-zentoast
Though not the recommended method, using a hammer and screwdriver to remove and install the axle nuts works in a pinch. I have used the aforementioned technique several times with no issues.
There is a locking tab with ears that you have to bend back before attempting to loosen the nut.
Dynosoar:zilla:
Good luck.
The best method I have found is to place a machinist scribe in the gap in the cone washer and a few gentle taps with a hammer inserts the scribe into the cone.
This expands the cone and walks it right out of the hub body. NOTE: this also works when you are tearing down the knuckles!
This is the simplest method, does not require BFH and does not mar hub body or studs...
:doh: Don't foget this!
not to be rude but this sorta makes my head hurt, just a little....
:confused:
No offense taken!
Can be hard to understand w/o a visual...
update please lunyou. as people said there are some tricks. and like mace asked-did you take the snap ring off?
cheers,
j
