real time tranny fluid check
Discussion in '80-Series Tech' started by MTNRAT, Jul 8, 2005.
  1. MTNRAT
    MTNRAT
    1,181
    18
    Mar 27, 2003
    Fernie B.C.
    What gear do you check the automatic transmission fluid in. Park neutral or drive. I don't have the FSM with me.
    Thnks,
    Sean
  2. beno
    beno Gihee Arakawa Moderator Supporting Vendor GOLD Star
    25,263
    Media:
    382
    Albums:
    29
    23,181
    Aug 28, 2004
    Woodstock, NY, USA
    From what I've read and the process I have used, do the following:
    Start the sucker up, and shift through all of the gears and back to park. With the engine running, check the dipstick--it should be at "cold" or near it.
    Then go drive around for about 15 minutes till it gets comfortable at operating temperatures.
    Go through all the gears again, put it in park, and with the engine running, check the dipstick--it should read "hot" or near it.
    Mine's a bit above "hot" but I'll live with it...
    Best.
    -onur
    Akron, OH
  3. MTNRAT
    MTNRAT
    1,181
    18
    Mar 27, 2003
    Fernie B.C.
    Thanks beno.
    Sean
