Real time PHH swap....Help?
КАГІҒОЯИІА
Okay, I am under my rig changing all the diff fluids and lo and behold, there is a red fluid dripping on the ground. Tracked to the PHH. Glad it is happening in my driveway and I just received my new silcon hose.
Question, do I need to drain the radiator to do the swap??
Or can I just pop it off and drain into a bucket? then refill?
Engine is cool.
Any quick help will be greatly appreciated.
:confused:
Drain the radiator. It is more controlled. Pulling that hose off with a full cooing system makes a mess and the spilled coolant is very toxic to pets. Dogs and cats in particular like to drink it and it causes a horrible death.
Use a bit of liquid dish soap and slide the hose up on the heater pipe as far as you can then rotate the pipe back into position and push the hose onto the bib on the head.
That's how my wife did it anyway...;)
Remove the hose from the top (the one that goes to the heater valve) and remove the top bolt (the only one that you can get to).
My wife did just fine...;)
Green stuff with a red core from Carquest. I could not get a good angle on it and she happend to wander by and over-hear the "discussion" I was having with myself....:rolleyes: and she said "Let me try". I said "Have at it" thinking to myself this should be good and sonofabitch if she didn't nail it in about two minutes...:eek:
:mad: So much for completing that sonofabitch.
Ruined my $25 silocone hose by gouging the SH*T out of it.
Off to Napa tomorrow for a $9 foot of the green stuff.
Then back to trying to get it to work.
I am very frustrated. Wish I had a wife. ;) Then...on the other hand...
Anyway, now I am scared that the metal heater pipe is going to break as I am moving it back and forth so much. Is this something to worry about?
Also, the top piece of heater hose on that pipe needs replacing as well, can I just use the 5/8" hose and put a bend in it or do I need a special toyota piece.
:doh:
P.S. Thank you C-Dan for your prompt assistance with the top bolt and such....:beer:
The top hose needs to have a molded in 90 degree bend. Can be procured from the auto parts store. Just tell them any 5/8 inch heater hose with a 90 degree bend. You will need to cut both ends to proper length.
If you are moving the metal pipe back and forth by bending it, then you may cause yourself more grief.
I removed (and replaced) both the upper and lower bolts mounting the metal pipe thus enabling complete removal of the pipe. This made the job very easy. Used a 1/4 inch drive ratchet wrench. Once it was placed on the lower bolt I placed a 18 inch bar against the wrench handle and struck it with a hammer to break free the bolt. Once the bolt was free, I operated the ratchet wrench by hand to remove the bolt. The 18 inch bar I used is a standard 1/2 inch drive breaker bar, with the swiveling square drive portion removed, leaving an open, forked end that was placed against the ratchet wrench handle.
I can empathize with your frustration. Definately a reason why they call it the PHH. I boiled my silicon hose, used dish soap and slid it on after only busting 3 knuckels!!!! You have to loosen the outer hose nipple (not the block) get both ends lined up and they rotate the right angle side inward making sure the clamps are on befor you do it...ask me how I know. Guess I've technically done the PHH twice :)
