Hi,
I changed my fuel filter about an hour ago, but now the vehicle won’t start. I’m stuck out at my shop, and can’t figure out what the issue is. I disconnected the fuel pump connector in preparation of draining the fuel lines. However when I went to start the car to Drain the fuel lines, it wouldn’t start. I thought it was odd because everything I’ve read says the car will start and then die. Mine didn’t do this, but I moved forward anyways. I changed the fuel filter and it still won’t start. The fuel filter is an oem replacement. I’m wondering if there are plastic caps on the new filter to protect the threads that I missed (but to me this doesn’t make sense because I was able to get the banjo bolts in. Thanks in advance for help. Please text me if you can provide any insight. I’m desperate. 608 658 7483.
