Real Time: HEater Hose Part #
Anyone have the part number for the heater hose that goes into the firewall on the drivers side. Yea, that one that is the most difficult one to R&R. My locat dealer cant seem to find it on his sheet.
Thanks
BRyan
Toad-It's a straight run of 1/2 inch hose. Go to the parts store and ask for Gates Green stripe. CarQuest usually carries it. You don't need factory hose. It is a total pain to change, and I removed the throttle linkage support bracket to get better access. The Green stripe will last as long as your Cruiser. Just remember, that hose is 1/2 inch unlike all the others that are 5/8.
It doesn't go into the fire wall but connects to a pipe that runs along the fire wall. there are different part numbers for different years FJ60, but you should be able figure out which one is right for you...
Thanks for the info.
If its not a formed piece than I'll just get some hose from napa like CDrew said.
Thanks for the pic MBB!
I got a different dealership to print that same one out and, like you said, it seemed like there were different ones for different years of the 60s, or maybe HJ,BJ and FJ. Mine verticaly leaves the L shaped hard like joint (87205from the above drawing) and enters the pipe 87248C pipe horizontaly. Is that the way yours is configured on your 60 as well Drew?
pic
Your fitting may just be turned upwards, but here are a couple of pics of mine. The first is from above, looking at the fire wall, the second is from the driversside.
Cruiserdrew is correct. Your fitting is turned 90degrees. I don't know if I would risk turning the outlet pipe back to stock configuration (who know what would break or start to leak). However, there won't be a dealer part number to replace the hose you have. Maybe just get a piece of the green strip hose...
