Real Time: Draining the Radiator on a 89' 62
Montana
I removed the front skid plate on my 62, where is the drain plug for the radiator? How much will i have to drain to replace the thermostat?
And use ZINC-based anti-seize .... Or if you can't find the zinc stuff, any antiseize when reassembling the t'stat houing. It will prevent the galvanic action btwn the steel bolts and Aluminum housing that eventually destroys the alum threads.
got it done, took maybe an hour. heater blows like a furnace now. And engine temp is perfect.
