I just rebuilt an SM420 to mate to an extreem Bends adapter, I used an early SM420 and it's out of a 2 ton truck, however on the end of the idler shaft in the rear it has a large washer with two bolts used to hold the shaft in the bearing, the lighter version has a snap ring around the shaft so the adapter will not fit over the bolts. Should I grind the bolt heads? Get a smaller washer? or has anyone used another tack to make it work, sorry the pic is so bad, thanks, Larry
