Re-torque head bolts: 'center' bolt : How ?
Reinstalled reburbed head.
In a week, ( few hundred miles) I torque check the head bolts.
How do ya do the 'cebter' bolt ?
. . .remove rocker arm assembly ?
. . . don't remove, use box wrench & pull real hard ?
. . .would a 'crow foot' fit ?
Thanks,
pete
A crows foot will fit but you have to adjust the torque due to the additional leverage.
Dynosoar:zilla:
OK, crows foot it is...
Yup, know about modifying (reducing) torque reading due to extra leverage...
Thanks
Pete
Detail Bump: (7 yrs wow!)
This Snap-On Crowfoot Wrench works well for torquing the center HB on a 2F. It will not break, nor damage the HB hex when torquing the bolt. It is a useful tool for a newly installed head (with non-stuck head bolts) that requires a few HB re torques after installation. This tool can eliminate the chore of having to remove the rocker assembly to gain access to the center HB.
Torque adjustment for it's 0.77" offset can be calculated from the link at the bottom when using a torque wrench aligned 0º with this tool.
https://www.motorcraftservice.com/renderers/torquewrench/wrench_formula_main_en.asp
For example: A standard 17.5" long torque wrench (center to center) will require approximately 4 ft. lbs less torque when using this tool when aligned 0º to apply the correct torque value to the bolt. When the Crowfoot is aligned 90º with the torque wrench, no torque adjustment is necessary.
If the center HB bolt has frozen in place from years of neglect, this crowfoot will not be strong enough to break the HB bolt free. The rocker assembly will need to be removed so a breaker bar can be used directly with a 6 pt. socket on the bolt.
Although Snap-On's Max Recommended Working Torque for this wrench is 525 in. lbs (47.3 ft. lbs), it's actual strength is much higher.
That is really brilliant.
OS got it...at 90* no adjustment is needed...
The things you learn just hanging around MUD..............
