Do ya'll re gear when adding larger tires, pros and cons?
Worth it for 35's? Especially if you are already in there to add air lockers?I think many dont bother unless over 315's. If you got to ask the benefits.....
That’s what I was ganna sayI live where the altitude changes drastically. I went 4.88. Much better now.
That's what I'm doing now, gearing and rear locker.Worth it for 35's? Especially if you are already in there to add air lockers?
Didn't know you could re-gear the transfer case. Is re-gearing the transfer case easier and cheaper that doing both axles? Would that put more strain on the driveshaft u-joints?As you go up in tire size, you’ll lose power with stock 4.11 diff gears. In high range you have slower acceleration, slower climbing grades, and worst performance in the mountains.
In low range you’ll drive faster over obstacles, have less control, and invite damage.
To maintain close to stock gearing you need to re-gear the differentials with 4.56’s for 35’s, 4.88’s for 37’s, and 5.29’s for 40’s.
Another option is to re-gear the transfer case with high range 10% underdrive gears which will give you close to 4.56 high range gearing. Most people also install low range 25% gear reduction.
Re-gearing will add torque to the drivetrain as a whole.Didn't know you could re-gear the transfer case. Is re-gearing the transfer case easier and cheaper that doing both axles? Would that put more strain on the driveshaft
Re gearing takes loads off the drivetrain.Assuming both high and low range gears are replaced, re-gearing the t-case is about 2/3’s the cost of the diffs. FYI - Installing the low-range gears is tight and requires some grinding of the case. If you only install the high range t-case gears, then the cost is only a third of re-gearing the diffs.
I believe re-gearing the transfer case is easier than the diffs. Both are above my mechanical skills and are being done at a shop. There are a few threads showing the process.
Re-gearing does place addition loads on the drivetrain as a whole, as do larger tires. In my opinion, the driveshafts are less of a concern than other weak points in the system though.
This opens a whole can of worms for what preventative maintainence to perform to prevent trail repairs.
Opposite experience here. I had 35s/4.88s on my last truck and while it was a huge improvement, it still felt like I could've used slightly more gear. Looked hard at 5.29s/35s this go around but that just felt a little too aggressive.The FZJ80 is my daily driver in the heart of LA.
35s/4.88s were a bit buzzy at hwy speeds. It always bothered me and the fact that my speedo was off by 3-4mph.
After 25K miles of that I went to 37s. Ideal for my needs. Back to near stock gearing. Speedo is off ~1mph. 75mph on 37s feels like 65mph on 35s.
For those who like related details, I did intentionally try to mitigate the upsized tire weight impact by going with a lighter weight AT tire rather than sticking with a heavier hybrid tire so I actually ended up being static weight net negative by a few lbs.
Knowing what I know now, I’d skip 35s/4.88s all together.
Please explain. What takes you to this conclusion?Re gearing takes loads off the drivetrain.
Also welding on front diff armor...
Yes, lower gearing gives you more torque or more load on the drivetrain. @96bruizer is saying the opposite, so I’m asking what his reasoning is.Generally speaking you can climb over obstacles better since there's more torque available, hence less need for the skinny pedal.
