Rattle on Slow acceleration
Discussion in '80-Series Tech' started by collector_edi, Jul 6, 2005.
  1. collector_edi
    collector_edi
    207
    Mar 30, 2005
    Indiana
    I am a proud owner of a 97 collector's edition bone stock. I have taken the advisement of others by not developing a heavy foot. I noticed on slow accelerations a rattling sound coming from the transmission or a metal plate under the vehicle. If I step on the petal the sounds goes away. I believe the previous owners did some towing with the vehicle and wonder if the tranny was stressed or if their is a loss plate causing the sound.
    I find myself stepping on the gas to eradicate the noise but would rather have it repaired.
  2. collector_edi
    collector_edi
    207
    Mar 30, 2005
    Indiana
    loose plate causing the sound? My editorial...sorry.
  3. TX_TLC
    TX_TLC
    1,480
    9
    Apr 29, 2003
    Texas
    cat heat shield....
  4. landtank
    landtank SILVER Star
    19,458
    1,837
    Mar 27, 2003
    Groveland MA
    check the shield on the front pipe right where it turns under the body in front of the first cat. Mine has total roted off, but in the interum it ratted quite a bit.
  5. JZenger
    JZenger
    91
    Jun 13, 2005
    Salt Lake City, Utah
    Sounds just like what mine was doing and it was the heat shield on the exhaust pipe that can be seen in the passenger side wheel well back and behind the wheel. My heat shield had rusted and was almost falling off. Based on a tip I found somewhere on here I used a hose clamp to tighten it up and no more rattling.
  6. collector_edi
    collector_edi
    207
    Mar 30, 2005
    Indiana
    Fascinating. I will look in that area and do a search to find out more about the clamp. The rattling is making my hair rise. It isn't too bad but I don't like the strange looks I am getting from the passenger.
    Thank you one and all!!!
  7. Draken
    Draken
    284
    Media:
    3
    29
    Sep 28, 2003
    PNW, WA aka wetside
    I had the same rattle....It was getting to the point that I almost did something about it :)... I had theorized that it was the cat shield and had read about it too...However just when I was going to do something about it...it rattled itself off and now no more rattle :). And to ease any worries...I haven't had any heat issues from the Cat.
  8. Brentbba
    Brentbba Former Golfer SILVER Star
    10,304
    1,210
    Mar 27, 2003
    OC, CA
    Ah Hell - just stomp on it, and report back in a few weeks on both the rattle and your gas mileage. hehehe
  9. Spydaz
    Spydaz
    390
    May 20, 2005
    Long Island, New York
    Rattle
    I just noticed the same rattle. What the heck is it?? It only is heard at slow accel and when the drivetrain is not warmed up. when drivetrain is warmed then sound goes away.
    Any ideas??
  10. stayalert
    stayalert
    1,804
    292
    Sep 28, 2004
    Norwich, VT
    see post #4 above.
  11. Spydaz
    Spydaz
    390
    May 20, 2005
    Not rotted. Truck has 41k on it.
  12. alia176
    alia176
    11,022
    Albums:
    1
    1,309
    Aug 21, 2003
    Tijeras, NM
    while you're at it, check the Tcase skid plate thing. If it's too close to the bottom of Tcase, then bend it down a little. It's flimsy.
  13. willmaxr
    willmaxr
    92
    Nov 17, 2004
    minnesota
    I had 55k on mine when I had the rattle. 3 or so hose clamps on the spot noted above in post #5 has taken care of it so far........
    Dang 41k miles. I was feeling good about my 73k.
  14. Spydaz
    Spydaz
    390
    May 20, 2005
    Found it. There's a nice small boulder in my damn cat conv sheild. How the heck do ya get that thing out??? I tried water..nope i tried a small tool....nope. Well any ideas?? The damn thing sounds like death until the exhaust heats up and expands. I guess i'll hit it with the power washer when i get home or i'm gonna grind the bottom off with my dremel!!!!
