I Have a 87 FJ60. I recently installed a Red head FJ80 power steering box. The new box seems a little longer. So how I installed it was removed the steering column then fitted the splines back in the shaft and bolted the column back to the firewall. At first I did not have enough room from the driver side to just install it like a normal person would. The "at times" issue I have now is the the two shaft pieces at the splined portion are so tight and don't slide very easy. So if my frame flexes at all the shaft stays extended and the top U-joint right again the firewall on the engine side rubs as I turn. Then the shaft will eventually compress enough where it doesn't rub. My idea was to separate the shafts, really clean it out and see if that loosens the sliding. Is there a lube that I need to put in there that would help?
