I did a search, there are some people who have posted similar "issues" happening with little or no follow up. Mostly 100 series off road..... I didn't see anything 80 series related (granted only went through 3 pages of search results).
Every now and again the 80 has a very mild "stutter" while driving. I've dismissed it in the past as a bump in the road (it's that mild). Today on my way to work on the freeway, it stuttered, looked down, the tach dipped down, up, then to 0.... all dash lights were on.
Threw it in neutral, pulled over to the side (still rolling), turned the key - fired up as if no problem, and finished the drive to work.
NO CEL.
I know it's 1 of 2 things.... fuel delivery (pump failure/lean, or even crack in AFM hose - though I would guess that would throw a code) or electrical. I'm guessing #2.
I also know that someone else has had their hands on the wiring for the ignition switch (for an aftermarket alarm at some point, but they used taps, and they're all gone at this point).
I will follow up with any photos, tests, and findings. Being that I've had the vehicle 10 months now and this is the first time it's happened enough to stall out - I'm guessing it may take a while to actually figure out the problem.
Just for background: New cap, rotor, plugs, wires - did a compression test with good results, new (used) AFM, good AFM hose checked (though unsure today), nothing in the oil/coolant (that's visible), new coil, EGR mechanically bypassed (it's a 93, had the factory sensor bypass in place), new battery terminals (though I didn't love them, they could also be culprit).
I'm thinking more along the lines of loose connection at a COR or EFI fuse/relay....
NO CEL.
