Ok I've searched but didn't find anything conclusive. No check engine light. It fired up pretty quick after the head gasket was replaced and ran smoothly for about 30 seconds before a random misfire started. It will go from smooth for about 5 or 6 seconds then a miss, then smooth again and another. It's not consistent like a dead cylinder. It seems to be a little worse at idle which it has a tough time doing. It idles low anyway after the battery has been disconnected for some time until it has a chance to relearn so that doesn't surprise me too much. If it dies, it will crank up and run smooth again for about 5 or 10 seconds then start with misfire again. My guess is bad cap/rotor or a vacuum leak somewhere under the intake. Thoughts?
