Random 40 60,62 parts (1 Viewer)
fogblanket
newport RI
well I have done a couple different build ups and used parts from every year land cruiser I think. I now have a v8 fj45 and alot of the toyota engine parts due me no good. plus a fair amount of random parts and some stuff I don't even remember buying. I wil try and gett it all up here and pics of everything. if you would like more pics of something let me know, but be advised my work banned Mud so it might be a few hours to get a reply and pics would take me a day probable. anyway here are the parts
pic1 sold
small pattern disk brake knuckles year unknown $20
pic 2
new (never used) transmission to transfer case by pass. got it from SOR $20
fj62 rear heater. bought used epoxcy primed and satin black ran it for 2 years in my 45but decided I need an amp under the seat more then I needed rear heat $30
(will get to the dzzy and coil later
pic 3
auto meter oil sender (electric) I thought it was a mechanical one ordered from summit for my v8 never even opened the pacakaging $20
random carb linkage parts I opted for a cable on the v8 so my collection of v8 and fj40 carb linkage parts must go $30 for the lot of them
2f alternator V belt $10
2f torque reduction started with positive lead ( this worked on my 2 f before the engine was pulled out of the donor fj60 I kept it as a spare ) $30
will add the other parts that are sort of visible in a later post
ok next set of parts
pic 1 brand new cork OEM toyota oil pan gasket $20
2f ac compressor (it worked 5 years ago when it was pulled maybe good for a rebuild or core exchange it has sat on my shelf since it was pulled) $25
complete set of 3fe gaskets both manifolds and exhaust doughnut (I had them as spares) OEM Toyota in original packaging $50 for all 3 (don't want to brake the toytoa staple holding them together)
pic 2
exhaust hanger bracket $15
3fe hoses I think its almost o complete set $30 sold
stainless steal hard front brake lines I think for a 4 runner calipers. I bought them and they did not line up with my configuaration till nice bend and new. $20
brand new set of front disk soft lines for an fj62 $30
fj62 greay sun visors in good shape $15
2f heater vlave bought from SOR never installed $30
pic 3
2f engine bay heater hard lines one new and one used both bought from SOR and never installed $40
ok the next three pics of parts
pic 1 sold
set of un opened shackle bushings for fj45 rear shackels but would fit fj40's as well I went around and around with Alcan about my rear springs and after 3 sets they finally did not sag. so every set of springs they sent I got another set of busings $20
pic 2
79 transfer cross member $80
frame mounts for 79 crossmember $30
pic 3 sold
64 clutch master $15
Is the heater control valve new? If it is I'll take it. Can you tell me how much to ship to Ohio, 44026.
ok it seems the rad hose are a hot compodity if you are first in line I have pm-ed you. as far as shipping goe I guess plan on around $10-15 bucks for most of the smaller stuff thinkgs like cross members and suck I will have to get an estimate on.
the Dizzy coil I believe is out of a 77-78 vintage. I don't know why I have it I think I bought it for my old 78 fj40 knowing is visibly broken or damaged but I don't know its working condition
a few more items
pic
horn from my 64 fj45lv you can see the plastic top is cracked $20
pic 2 another of horn
pic 3 fj62 grey visors already listed just another pic see above
I took like 24 pics of parts just trying to get them all up here
pic 1 another of above mentioned horn (I may have the low horn too this is the high horn)
pic 2
above mentioned Dizzy/coil but I did not put a price on it. say $50
pic 3
stock 64 accelerator pedal epoxcy primed $15
oil filter brakcet with oil cooler mounting $20
pic1
oil filter bracket without oil cooler fittingsok last ones $20
pic 2 and 3
are of a set of 78 front axle hobs and a pair of 88 front axle hubs I removed both due to running a wider rear axle and mount a sky widening kit on the front so I used mini truck front hubs both are in good shape no problems with them $20 for each pair. with them come used bearings and used greeese. would prefer not to ship but if you need them will ship but the shipping will prolly be more then they cost.
will try and get some pics later bt I have uneartheed some more quality parts
pic 1
SOR chrome 74-86 slave push rod. I paid 30 for it but come to find out I have to cut 2" of the push rod in a v8 application so I used a used stock push rod in stead $20
pic 2
87' 2f clutch fork $10
pic 3
I also have a 2 day old 87 slave (this is when I figured out I had the wrong slave as I sat on the side of a busy street stuck in second gear:() $20
pic1
- 2 year old clutch slave (seemed with the AA kit you have to run a 85 or older fork and slave I ofcourse did not know that and ran the stock 87 slave for a month until the push rod broke the seal. it is fine just won't work for my application any more.$15
pic 2-3
I bought a set of new fj40 rear heater hardlines and ran them for 2 years. they are in good shape. $30 for the pair
Pm s replied too checking on knuckle fitment into a flat rate box
Interested in the bushings. Still available?
Interested in these
I have busshings and the cross member mounts still availible.
on the knuckles and hubs I can fit one knuckle and spindle in a large flat rate box. and I could fit both hubs in a 3rd box for a total of 3 large flat rate boxes to ship. let me know
Jason
some more stuff
pic 1
I have two new speedo cables for a stock fj40 cluster and transfer case. I belive they are late 70's early 80's vintage. again with my many buids I belive i was trying to fit a 87 transfer case to an early 40 cluster. I think I needd the thread on for the cluster not the clip on. these are both clip on. anyway $20 apiese
