Rancho shocks on lifted HZJ77
Hi,l am in the process of doing a 3" lift on my HZJ77,l use OLD man EMU shocks front and rear.l can get the numbers tomorrow if you are interested.
Simon
Winnipeg
Hi Ron,what pump do you use to run your Hyd winch,l have one of the and thinking of repowering it.
Simon
Simon
To be honest, all I can say it's 6.5 cub cm. In other words it displaces 6.5 cubic centimeter of fluid each revolution.
The pump itself is a very common hydr. pump used by professionals and referred to as an "italian pump"
I builded the setup myself and did the calculations myself.
You have to know that the pump is driven by the crank by means of a V-belt.
I used an A/C electric coupling in front of the pump so it will run only when needed.
At that time I was afraid the coupling would not be able to handle the torque needed for a pump with higher volume (say 9.5 ccm) and therefore choose to have a smaller pump and use a higher RPM.
If I had to do it again ( and maybe I will some day) I would use the higher volume pump. I'm confident the coupling will handle it.
A remark: because the pump can deliver almost double the pressure Milemarker specifies, I've a setup with a safetyvalve that dumps the pressure as soon as the allowed pressure is reached.
I also use a radiator to cool the hydr. fluid. It's a small oilcooler radiator, but it allows me to winch without limits for hours without any problem under full load.
