why do the cabinets open to the front of the bar?
The soss hinge will put a lot of stress, on what I assume are 3/4" thick styles and rails.
okay looks cool, you could have just made the raise panel open and the framed fixed and made the foot rest part of the cabinetry design eighty sixing the brass looking thing.
The door could be reworked to create a hinged panel. However, you would then see a reveal (gap) around the panel as it would essentially become an inset door within the original door's frame. That is a pretty creative solution.
Although not as technologically advanced as the European hinges, a good ol' piano hinge could easily be installed at the bottom and a simple ball catch could take care of the top. The hinge would likely be slightly thicker than the current door reveal so you might need to joint 1/16" off of the bottom.
Brass Ball Catch - Rockler Woodworking Tools
or hire an architect..
Create a inner frame attached to the back of the door just big enough to fit the opening. Then flush mount some strong magnets in the frame. And when you want in just take the whole door off.
I realize the OP has ordered the hinges. However, if the magnets are an option then some other options would be KEKU push fit fasteners or panel Z-clips. I've used both of these many times.
Cabinet hardware from Accuride drawer slides to Blum door hinges by Specialty Supplies
Monarch Z Clips | Panel Clips
Why not make the outer frame permanently attached and just have the inset panel open on some sort of hidden hinge.
