Radiator whoes.
Discussion in '80-Series Tech' started by photogod, Jul 4, 2005.
  1. photogod
    photogod
    1,579
    8
    May 21, 2004
    MN physically, MI spiritually
    So after all my work on upgrading things on the 91 I see fluid dripping from under the beast today. It's Rad fluid leaking from the seam next to the rad cap.:crybaby: I have done searches and didn't see much definative on rads for 91's so am looking for info on replacement. Does a 93, 94 three tube brass fit a 91 or do I have to go with the plastic 91, 92? CDan is going to get another order this week! :mad:
    Thanks for the input.
  2. Koffer
    Koffer
    2,207
    8
    Jul 14, 2003
    Hopewell NJ 08525
    Look at it this way try to get 14 years out of a rad in a us made are of the same year and miles .
    You wont have replace it again till almost 2020 :D
  3. thorvald
    thorvald .......
    1,574
    Media:
    19
    Albums:
    2
    26
    Aug 18, 2002
    on the ice, wyoming
    might want to check your power steering lines now since the radiator has to come out to replace them ;)
  4. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,720
    7,574
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    The 91-92 radiator is different.
  5. photogod
    photogod
    1,579
    8
    May 21, 2004
    Hungry dogs need to eat.....
  6. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
  7. beno
    beno Gihee Arakawa Moderator Supporting Vendor GOLD Star
    25,261
    Media:
    382
    Albums:
    29
    23,137
    Aug 28, 2004
    Woodstock, NY, USA
  8. photogod
    photogod
    1,579
    8
    May 21, 2004
    T stat, fan clutch were replaced at 120,000 so I won't be doing that. I might consider the PS hoses as those are leaking slightly. Thanks for the thought.
  9. Cruiser Jimmy
    Cruiser Jimmy Moderator
    2,073
    Media:
    100
    Albums:
    4
    587
    Sep 15, 2004
    Grand Junction, CO
    Photogod,
    I had to replace my radiator due to the exact same problem. Hair line cracks right next to the cap.
    I got a rad from radiatorbarn for about $184.00 if I remember correctly.
    In the end, I've basically replaced all the coolant components on the rig as the prior owner had the T-stat broken and didn't fix for a long time.
  10. photogod
    photogod
    1,579
    8
    May 21, 2004
    JK
    How long ago and how was the fit? I hesitate to put in aftermarket as there seems to be a bit of do it again in a year syndrom due to the lack of quality.
  11. Cruiser Jimmy
    2,073
    Media:
    100
    Albums:
    4
    587
    Sep 15, 2004
    Grand Junction, CO
    Pgod,
    I've had the radiator 1 year and 4 months. I've never had a problem with it.
    The fit was just like factory. Exact same mounting points compared to stock.
    The only thing I had touble with was that it was a bitch to get the stock out. No FSM when I replaced them out. Getting the new one in was not difficult at all.
