Gretsch
So got home tonight and noticed coolant on the garage floor. Got under the truck and see a drip coming of the radiator just below the over flow bottle. Thought maybe the bottle had split but I felt under it and cannot feel and coolant under it. I got under the truck again and notice the radiator seems to have a bead of coolant running along under it. The lower radiator hose seems moist on the outside of it. The truck has a slight lean to it so thought maybe coolant is leaking out of the hose and running the length of the lower radiator tank. I tightened the clamp a bit to make sure she was tight and sealed. Started the truck up and watched for leaks. I don't see any leaks from the lower hose but its still leaking on the drivers side of the radiator. I tried to see where coolant is collecting but with the fan shroud in place its hard to tell where its coming from. I took some video of the leak happening on the drivers side.
Seems like its coming from the weld on the corner of the tank. Not sure if its leaking down from elsewhere on the radiator and is just showing up at this seam or if this weld seam is part of how the lower tank is sealed and its cracked and leaking. There seems to be some coolant inside the fan shroud. Photo is not that great for illustrating but maybe someone can tell here.
Is this a common split area? I had this radiator hot tanked and cleaned about a year ago and its been rock solid until now. Should I just bite the bullet here and fetch a new radiator or try and have this one fixed? Looking at this one as a replacement.
CSF Radiator
Seems this one was still in good standing with the community as far as quality if memory serves. Any recent opinions on it? Not looking to go aluminum at this point if I can help it but will consider it if folks deem it a better option. Thanks in advance for the help here.
CSF Radiator
