"Merry Christmas"
now Beowolfs statment makes sense
. The only change I made was the method used to flush the system. I didn't have a Prestone kit
, so, I drained the radiator and retightened the drain plug. I opened the heater control valve. Then I took the top radiator hose off at the radiator (using a make shift hose extension I was able to drain the hot coolant into a five gallon bucket, while replenishing it with fresh tap water from a water hose at the radiator fill spout). I filled the radiator back up with tap water. Then I had an assistant start the engine a let it idle. It took a little time to get things cooking, but once the thermostat opened it was easy going. CAUTION: The flushing coolant is very hot. Wear gloves while handling the make shift drain hose and use hose that can handle the temperature (195 F or so). My assistant and I continued to fill and flush until clear water ran in the bucket. I then shut the engine off, put the top radiator hose back on, then drained the radiator and block. I tighten the radiator drain plug and reinstall the engine drain plug. I drained the overflow bottle and cleaned it out. At this point I followed the fill instruction Beowulf gave on this thread
