Radiator flush kit - T location
Discussion in '60-Series Wagons' started by zcruiser, Jul 10, 2005.
  1. zcruiser
    zcruiser Needs monitoring
    1,205
    12
    May 7, 2005
    Hillsborough, NC
    Need to put a Prestone flush kit on my FJ62. Before I cut a hose, wanted to confirm that the "T" goes between the two green lines I've marked on this hose:
    [​IMG]
    TIA, don't really see any other place it could go....
  2. schaats
    schaats
    284
    5
    Apr 3, 2005
    Kyunggi, South Korea
    I also bought Preston flush kit but still I didn't install because I couldn't determin which hose I must cut
  3. Exiled
    Exiled
    1,939
    186
    Jun 20, 2004
    Round Rock, TX
    On an Fj62 that I parted out earlier this year, a PO had installed one of those flush kits, but the T was installed much further back, on a hose line closer to the firewall on the passenger side of the engine. Sorry, I don't have any pictures.
  4. 123c
    123c
    134
    Feb 1, 2005
    East Wenatchee, WA
    If that is the highest place the coolant is going to flow through, then it's the correct place
  5. zcruiser
    1,205
    12
    May 7, 2005
    Hillsborough, NC
    Thanks, all. I read some instructions on rad flush, but it mentioned needing a 2" section of 5/8" hose to do the job. I can't see needing any extra hose in this location, in fact plan on taking OUT about a 2" section in the hose in the pic to put in the T.
    I probably won't get to this until August, but will update with an installed pic when I do for future reference. Seems like the right place to me.
  6. 60wag
    60wag SILVER Star
    1,929
    50
    Jun 25, 2003
    Boulder, CO
    I like to put the flush T up near the fire wall near the heater control valve. It makes it simple to vent the air out of the system.
  7. import silvia
    import silvia
    471
    3
    Feb 14, 2005
    Tucson
    I always put my flush kits on the heater lines near the firewall.
  8. stinkyfj60
    stinkyfj60
    1,344
    3,384
    Apr 22, 2004
    Roodepoort, South Africa
    I just recently purchased one too for my FJ60 and its directions cleary said to intall it on the heater line near the firewall...
    That seems to be the easiest place to access it too.
    Jason
  9. CruisinTiger
    CruisinTiger
    2,973
    146
    Oct 22, 2004
    Clemson, SC
    Yeah I put one on my 40 and I have it comin between the oil fill tube and the water pump. It flushed it so I'm assuming I put it in the right place.
