Radiator fan vs electrical fan
Hi guys did any one change the the original radiator stock fan with electric fan withe same size?
I had to drive in city with low speed the heat increase and the Ac not cooling well , the weather is to sunny and temperatures is over 45 degrees Celsius🌞🌞🌞
original fan moves more air...
id check your ac charge not the fan
If you search, there's a few write ups on it. The overall consensus is that the motor fan moves more air than electric. Some guys fill their fan clutch with thick viscosity fluid to move even more air.
I don’t think the thicker fluid is to move more air as much as getting the fan to come on sooner🤷‍♂️
Absolutely correct. It removes the "ramp up" period and essentially makes it an on/off fan.
