Sacto60
1987 FJ60 2" OME 33s
How much capacity should I expect when i do a simple radiator drain/fill? I opened up the rad drain plug, opened the rad cap, and maybe got about 1.25gal of coolant total. Good news is, what came out didn't look all that bad. But when I went to refill some distilled water and run it until hot, it took about 2.75gal of water. I'm parked on level street surface, did some upper hose burping, and ran it with heat on blast. I was able to add just a little more as the truck was running, but again wouldn't take much more- in fact, started to overflow. Temp never rose much at all. Isn't the 2F coolant system over 4gal? I realize there's likely some in the block, right? If the thermostat won't open while running the truck, I'm guessing that's the reason the volume caps at under 3gal?
