Radiator concerns
El Dorado Hills, CA
For my 1997 AE I have noticed the radiator is really starting to discolor. It is original with 190,000 miles. As PM I am getting ready to flush the coolant system and replace the Tstat and water pump. Thinking it my be smart to replace the radiator while I'm at it.
What else is original? Heater control valve?
Clean engine bay though.
Even if it still cools properly, that thing is done. Replace now before something like this happens:
Also any other old components like heater control valve, hoses (particularly hard to reach like the PHH), etc
Haha. Readying that post was what got me worried. It didn't help i read it the night before towing my camp trailer up the same roads.
Add new rad cap to your list as well
Add new rad cap and a blue clutch fan with 15k viscosity to your list
I need to re-read the fan clutch mod thread. Can't I just change out the fluid in the clutchbi have. Why does it need to be a blue one?
You can save $ by replacing your current with higher viscosity and modify it for 95f.
Blue is popular clutch for our 80 to mod. If you have a black one, it is rebuild-able and in my opinion is better w/higher visc and time it to 95f.
Once you have the rdiator out it us easy to do some other coolant parts like belts, fan clutch, t stat and even the water pump. It has been a few years but i dont think the oem water pump was really that expensive. Or if you reallt want to do a "while i am in there" good time to do the oil pump cover.
Thank you all for the great input. Any recomdatuons for the best flush additive to use? I want to flush the system before dropping in any new components.
I used some Blue Devil flush about a year ago. Think it worked well. Found it at a local parts store.
Plus oil pump cover seal, front crank seal and the 3 belts.
do the flushes with the old rad in so it can catch and gunk then install a new one when your done flushing the system. i would also replace the t-stat, waterpump if your unsure of the age or mileage, fan blades if your doing the fan clutch as they are also plastic and will deteriorate with age and if rust is a concern you may want to consider looping out the rear heat as the lines on the body are steel and will rust out at the worst time.
Did you replace all the water hoses in the intake plenum?
Front crank seal and the oil pump seal like mentioned above.
I just did distilled water for a week in mine before going back to antifreeze. Flush both directions thru the heater core.
I've had radiators fail that looked way better than that...
