R/T: pulling steering wheel
Steamboat Springs
hey guys, took the 3 screws off the horn cover, took the main nut off the steering column, but i still cant seem to pull the steering wheel off.
i got pretty agressive with it pulling on it, wiggling it around.. still no dice. wont budge.
any tips? did i miss anything?
thx
There are such tools as steering wheel pullers. Usually a two bolt or three bolt puller similar to harmonic balancer puller, but lighter duty.
I've always just pulled them off. Try gripping the wheel at 9:00 and 3:00, and pull alternately. You're sort of wiggling it back and forth while pulling hard. Some take a fair amount of force, be careful that when it does pop free that you don't cause yourself a trip to the dentist. I've come close a couple of times......
I too, dealt with this a coupla weeks ago. Alternately pulling at left, right, top and bottom wiggly style got it loose. You WILL want to keep the nut dialed in a couple threads, that way the wheel won't hit you in the face when it does come loose... GL
I strongly agree with that ..
thanks fellas i'll give it another shot today.
