R & R tranny this weekend, what am i missing?
in the garage
hopefully putting my sm465 in the 40 this weekend.
the tranny came with a A A adapter that is about 6" long for the t-case.
got a 3spd bell housing
4spd pres. plate
sm465 disc that's 11"(looks like it will work no prob)
3spd t-case reinforcement plate( thanx poser, hope it gets here in the next two dayz ;) )
pilot bearing i still need.
ONE QUESTION:
am i going to be able to still use the vacume actuator for the t-case?
since the adapter from trans to t-case is the old school AA adapter thats 6" long!
i know i'll have to modify the vacume lines, but is there going to be room under the floor pan for the actuator? (ok, two questions)
all replys are welcome
thanx
jim
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
You are stuffing the v8 in there right?
You are missing a 500 lb gorilla to lift that badboy. That was the hardest part of my swap. I couldn't fit the tranny under my LC on the trannyjack I had. A real bugger to lift off your chest. Also don't forget to change the bearing retainer bolts for Capheads and turndown the beraring retainer to fit hole in Bellhouseing. Also workout your T-case shift - tranny plate before you put it in if you use a floor shifter.
in the garage
NO, thats the 60. stuffing it behind a 2f
this is the 40.
i thought i saw someone post up that if your t-case gets moved back, that the vacume diaphram hits under the floor board.
i want to keep the vac shift feature..:cool:
the sm465 has a old school AA adapter
in the garage
engine hoist ;)
Montgomery Co. TEXAS
Website
missionsonwheels.org
I'm not sure about moving it back 6". Your gonna have to move the crossmember and you'll have to clear some of the floorboard and hump if the adapter doesn't clock the t-case down a bit.
My SM420 and 1" plate adapter required some reworking of the floor boards and tunnel (which I'm still reworking). I original cut the rear motor mounts bushings in half to make fit but that's not a real good plan IMO.
You could always add a 1/2" or 1" body lift which should help everything but the crossmember.
Post pics and let us know how it goes.
in the garage
will definitly post pics
i'll post a pic of the tranny with the adapter, it will give y'all a good idea of what i'm talkin bout.
jim
The Rockies or the Andes
I failed to notice "beer' in your parts list, so I can only predict that this project will be a failure. Carry on :flipoff2:
in the garage
( in a curly howard voice 3 stooges)
oh, wise guy huh!! yuk, yuk, yuk,
in the garage
ok, just for grins.
here's the trans with the adapter
lookin last night i think i have room for the actuator, but its the linkage on top of the t-case i'll have to deal with...
thanx all
jim
denver
Honestly I really think getting the vacuum stuff to work is the least of your worries, like said above x-member will be a B, and talk about short D-shaft. I'm still running the vacuum switch with my sm420 if you didn't remember, I didn't have to change anything. I did lengthen my rod for hi low like 3", no big deal. Worst case is you have to cut more stuff out of the way. There are some body supporting channels that you will prolly run into.
in the garage
yup!
x-member and body supports.
aint nothin a welder and some tube wont take care of ;)
anyone feel like comin down to castle rock tomorrow? ;)
i would be happy to help if you buy me a tank of gas... castle rock is a long ways from salida.
hope all goes well, carl 607-227-9585
