I’m replacing the steering pump in a 2002 body 2003 engine LC. OEM Toyota steering pump arrived without nut on pulley. Was going to use the old one. I can not find the torque value for this nut any ideas?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Thanks found one the right size and torqed it to 50f/ Lb Belt and braces approach.It "appears" as if no bolt is needed. Parts catalog shows none either. Used parts show rust... and probably no bolt. So....
