I need to replace my split intake tube. Will the 95-97 intake tube fit a 1994 fzj80? Thanks
If it's all the same part, then I would say the eBay lister didn't do their due diligence.I see the intake tube listed on part websites and eBay as fitting 1991-1997 and then fitting 95-97.. which is why I'm confused.
It will fit if you cut an inch off the AFM side. There is a rubber lip that you use as a guide. It will definitely not fit a 91,92.
Absolutely.. thanks for the infoTest fit before you cut. I bought an eBay one listed for the 95+ to install on my 94 and it fit fine. Sure glad I didn't just cut it first.
That sounds legit to me! Seriously, though, that is pretty logical. Credit given.Haha @beno I think you are giving me a little too much credit. If I had to guess and this would just be a wild guess is that the later tube has the external reinforcements to keep it from collapsing with really high under hood temps and clogged air cleaner.
