Quick tranny fitment question - H42 to 9/73 clutch
Greenville, SC
Are there any compatibility issues mating a late model H42 (this is a placeholder tranny for a later H55 swap) from A FJ60 to a 9/73 FJ40 clutch setup (was a 3spd/F engine).
I have a transitional 3/4spd bellhousing so the bolt-up should not be a problem, cross member will be moved back, and rear springs were flipped to provide about 4" of extra length to pumpkin. Using F engine flywheel, and swapping in 3FE.
TIA.
No, no clutch issues. The transmission spline and snout diameter is the same for all 3, 4, & 5 speeds behind F series engines. There may be linkage issues to work out w/ getting the 3 finger clutch parts to fit inside the 3F bellhousing, but it should go alright as long as you use all the matched parts (release bearing, fork, pivot ball, slave, pushrod...)
My 69 3spd bellhousing had to be changed because the bolt patterns were different on the 4spd trans when I made the change out. I also had to change the output shaft on the transmission to adapt to the older TC. This was a 75 4spd install replacing the 69 3 spd. I also had issues with the crossmember that have not been corrected that I wish I would have done while the trans/tc was out because it is very tight against the e brake housing. You have to have to drop the rear of the engine and raise the front to get the trans/tc in if you do not modifie the crossmember. IMO it was a good improvement to the truck.
Thanks -- the bellhousing is actually the one you sent me with the rebuilt axles a ways back -- not a 3F bellhousing, it was supposed to be a transitional bellhousing between F and 2F I thought. Seemed to bolt up to the 3FE...
I was going to buy everything but the flywheel new anyway, would the later model clutch and flywheel setup be easier?
I'm using a later model bellhousing so hopefully I'm covered there. I was hoping to use the t-case that came with the H42, not the 3 spd case -- I have my emergency brake on my rear disk brakes. The longer FJ60 H42 has the spacer in the middle (making it the same length as the H55), which is why I am moving the main crossmember back a bit (and adding a tranny support).
Thanks
Oh yeah, I remember now. There is plenty of room in that bellhousing for the clutch release bits, plus it is bisexual for right or lefthand slave mounting.
For serious crawling I personally like the 74-older clutch & flywheel. There is a HD pressure plate available from Toyota for old FJ45 and the flywheel has a much higher polar moment of inertia, which means harder to stall at idle.
For ease of install, I would recommend updating to the 75-newer diphragm clutch, release fork, bearing, slave & master cylindrs.
