Quick tranny drain/fill question... (1 Viewer)
South Jordan, UT
Going to do the drain and fill on the tranny today. Anyone have any reason why I should or should not do it with a warm tranny?
Hayes
slater,mo.
mine was warm when my mechanic did it.he said make sure you use the toyota red gasket maker.the previous history on service was unknown so i was very happy to see how good it looked in the pan.
powderpig
Boulder Foothills, CO
If it is winter and you have a real cold climate, the fluid will not flow that well, stuff will stay in the bottom of the pan and not move as well. That is the only negatives I can see. You may want to take a before and after look at the dip stick to make sure you fill about the same. then check later when the truck is full warmed up to make sure you have not overfilled. later robbie
slc area
If doing the drain without dropping the pan it will drain 4 quarts. Refill with 4 quarts and it will be just about exact. Just did it last week.
Flatwater, NC
Do it warm. It will drain a bit quicker. If you are not pulling the pan for a filter change and wiping the gunk of the bottom of the pan, it shouldn't take more than 4.5 to 5 qts....
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
