Quick Timing question, stock setting on 1991/1992?
Waiting on my FSM to come in but need the spec in the meantime. I searched and found the info for newer engines as 3 degrees BTDC , but did not find mine. I'm likely going to advance it a few degrees this weekend. As a side question, I'd be intrested to hear others experience with this as well.
Thanks in 'advance' :D
Bump, anyone with an FSM for 1991-1992 that can check this for me? Getting it in this weekend for service.
SoCal
Its 7' BTDC. There should be two marks on the flywheel, one is TDC, the other is 7 below. Good luck!
Austin, TX
Wish I had this info yesterday damnit! I spent almost two hours getting my timing right when I replaced the distributor. I got it so close and then realized I had installed it 180 degrees the wrong way :doh:
