Quick! Need mechanical help
Discussion in '40- & 55-Series Tech' started by drohweder, Mar 14, 2004.
  1. drohweder
    drohweder
    1,151
    2
    Oct 5, 2003
    Golden, CO
    Got a SBC with long water pump in my 55. For the heater hoses, what end would hook up to the OUT or INFLOW to the heater? I've been looking online but can't find a quick answer so am hoping on of you can tell me! Thanks :cheers:
  2. drohweder
    drohweder
    1,151
    2
    Oct 5, 2003
    Golden, CO
    Come on! Help me out! Please :D
  3. kc_chevota
    kc_chevota SILVER Star
    1,303
    157
    Feb 19, 2003
    Kansas city MO
    on mine the heater valve is connected to the water pump the other one is connected to the intake manafold
  4. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,305
    Media:
    17
    Albums:
    1
    621
    Oct 1, 2003
    MN
    The Toyota heater hose routing is from the top of the heater control valve to the rear of the cylinder head, and the pipe/hose that does not attach to the heater control valve, runs to the lower hose, which could be attached to the water pump...
    Good luck!
    -Steve
  5. aZ..fj-40
    aZ..fj-40
    99
    Nov 15, 2002
    Tucson, Az.
    The hose from the intake manifold is going to the " in " side of the heater, and should have the shut off valve in it. The return line goes to the water pump.... HTH, Earl
  6. drohweder
    drohweder
    1,151
    2
    Oct 5, 2003
    Golden, CO
    Thanks, I ended up having it on correctly...can you run those in reverse/backward flow? Anyway, thanks again, I appreciate the help here :)
