Cruiserdrew
On the way there
Bad numbers!
I think that with elevated NOX, the first place to look is at the ERG system. Does it operate and do it's job?
Hydrocarbons and CO are like related to the catalytic converter.
It is also possible that the air injection is bad-that could also cause high hydrocarbons and CO-since the air injection supplies the oxygen to allow the catalyst to do it's job.
Always start with the cheap stuff, though. Tune up, change plugs, set the timing, adjust the valves. Then pay the $30 and see what that does to your numbers.
This is why you always do a pre-test on these trucks and avoid being labeled a gross polluter and then have to smog every year.
