A mate bought a hilux with a blown motor that had a rod out the block and it has a safari turbo kit on it ,
It came with a "good motor" in the back of the ute but seems to have it's own issues
What motor, model, size is in the hilux
What motor etc is in the tray
Will they swap into each others place
Can they turbo manifold fit onto the motor in the tray
This is the "good " you can see the key hole is rounded out and also the gear on the crank has slop/play , I recommended not to use this motor , what can be done about this problem?
This motor has 3l on the block?
This is the motor in the hilux
Any know what the motor and details are
You can see the hole in the bock near the starter motor
The hilux is a sr5 duel cab 1992 does any know what motor this comes with originally
Cheers
Cheers
