I had the lower ball joints, inner/outer tie rod ends, and cv axles installed by a local mechanic with a good reputation. I had bought the parts online (ACDelco, Sankei 555, and Toyota, respectively) and intended to do the work myself, but time got away from me and I wanted it done before an upcoming trip. I could see I needed new outer tie rods, so I just went ahead and bought the kit that had both inner and outer to be conservative. My wife picked up the truck after the work was done, and they told her the rack an pinion needed to be replaced because it was leaking. Isn't that what the inner tie rods connect to? Shouldn't this shop have called us when the truck was apart on the lift to tell us this?
I will monitor the power steering fluid, but the truck drives and steers fine. There was some grease on the lower control arms, but I thought that was coming from the CV's. I have not noticed any stains on the driveway. If I don't see the power steering fluid reservoir dropping, is it fine to keep driving it for a while, or is that asking for trouble? Also, can I get the rack and pinion without the inner tie rods from anywhere, or did I basically just waste the money on these new inner tie rods?
Any input would be greatly appreciated, thanks.
