I'm getting a rhythmic soft grinding/brushing noise that I can hear at low speeds. At higher speeds, wind and road noise mask it:
- It feels like it's coming from behind me.
- It's variable with speed.
- At the low speeds when I hear it, I can silence it by shifting from D into N. Coasting in N = no noise regardless of engine RPM.
- The noise is present whether or not I am braking.
- The noise is there in both 2WD and 4WD.
Other potential clue: I get a slight "thunk" shifting from P into D or R, and a similar thunk on occasional downshifts.
My mechanic suggested it's a front wheel bearing, but if that were true, I should be able to hear the noise while coasting. I am thinking driveline: U-joint(s), differential bearing, or slip joint (the thunk). If so, what's the best diagnostic process to determine which? I'm reading up on lubrication here.
Thanks!
Thanks!
