Questions about cam repair.
Have you ever been screwed on an eBay deal due to inaccurate description?
  • Yes.
    Votes: 7 41.2%
  • No.
    Votes: 8 47.1%
  • Yes, but it all worked out in the long run.
    Votes: 2 11.8%
  • Total voters
    17
I recently bought a cam from a guy on eBay who said the cam had "no visible damage" but when I recieved it there was an almost 1mm deep groove worn into the thick part of the fuel pump lobe. The rest is in pretty good shape however.
Can this be repaired and reground? Is it useable as is? (I would not feel good about that)
Or did I get screwed?
If not can someone recommend a place that does good work?
Thanks,
Scott
Your poll should ask how many Ebay screwings out of total number of purchases. Also, how you asked the question will bias those who answer. I got screwed once out of 5-10 purchases, and on a pair of FJ mirrors. The seller later offered to buy them back, but I'd already modified them.
In your case, I'd definitely leave negative feedback (I did, & the guy said it "wasn't fair").
Don't know for sure, because it probably depends on how much your cam might already be reground, but any cam grinder should be able to regrind just the fuel pump lobe.
I've got to agree with the previous comment. A used camshaft? I'd never buy (or sell) a used camshaft except as a core. You didn't mention lifters. You did at least get the lifters which have worn to match the lobes didn't you?
What does "pretty good shape" signify?
FIW, the groove in the fuel pump lobe can easily be repaired.
Mark...
What they all said. But never expect 100% when you are buying used parts; you'll win some and lose some. Buying from a reputable seller and asking questions before completing th transaction is highly recommmended. Exra pix can always help too.
