Hey! Just got back from holiday and noticed my brakes have gotten harder to push in. They do get easier to push in after the truck has braked a couple times but the initial braking from a stop is like with no booster at all. I replaced the booster vacuum valve and hose with the kit from wits end back in October. My brake pads are at 2mm in the front and slightly more in the back but I'm just gonna go ahead and overhaul this system. The axle to caliper brake lines are original and old so I plan on replacing them (In addition to frame to axle). The brake fluid is dark and old but before I attempt to flush it I want to have the parts ready.
Here is what I plan to replace currently:
- Napa Ceramic Brake Pads (F/R).
- Napa Eclipse Calipers (F/R).
- Wits end SS Extended Brake Lines (OEM are aged and cracked).
- Brake Fluid
- Deleting the ABS and LPSV
- Do you think this is a fluid related issue or a booster related issue?
- Should I also replace the brake booster while I'm in there? This is the one I've been told is the OEM solution (80 Series, NEW OEM Seiken Brake Booster and OEM Gasket, 44610-60792)
- Should I also replace the brake master cylinder while I'm in there?
