Question regarding Cats (converters not feline)
Discussion in '80-Series Tech' started by phxtlc, Feb 26, 2007.
  1. phxtlc
    phxtlc
    585
    1
    May 20, 2006
    Plano, TX
    Does it make a difference how far back a cat can be mounted from the manifold? Does exhaust temp affect how efficent they perform?
    Thanks.
  2. IBCRUSN
    IBCRUSN
    2,165
    Media:
    7
    Albums:
    2
    7
    Sep 13, 2003
    Wichita, KS
    yes and yes. Off the top of my head I don't recall the details but the distance effects temp which effects the cat getting to light off temp. The closer the better. The farther away the cat gets it may not light off and not perform correctly and IIRC if it doesn't reach temp it won't last very long before it fails.
  3. Walking Eagle
    Walking Eagle
    3,225
    31
    Sep 6, 2003
    Tulsa, OK
    x2....
  4. RavenTai
    RavenTai
    6,048
    38
    Nov 16, 2003
    Dixie co. Florida
    you could do some exhaust wrap to compensate.
  5. Walking Eagle
    Walking Eagle
    3,225
    31
    Sep 6, 2003
    Tulsa, OK
    ya', but that's just added cost, and then it gets wet...
  6. IBCRUSN
    IBCRUSN
    2,165
    Media:
    7
    Albums:
    2
    7
    Sep 13, 2003
    Wichita, KS
    then rusts
  7. ThePookieBear
    ThePookieBear
    867
    Nov 9, 2006
    Wichita, KS.
    Have any of you run those cats that the ricer guys use? The "off road use only" ones that supposedly add horse power. They seem to be pretty much a straight through flow with little resistance. What happens if you run with out the cats completely? Other than smog stuff but suppose that wasn't an issue.
  8. RavenTai
    RavenTai
    6,048
    38
    Nov 16, 2003
    Dixie co. Florida
    had no problems with rust on a previous vehicle, had stainless exhaust like the 80.
    If you are going back with steel in the salt belt i could see there being a problem.
  9. cary
    cary
    3,118
    41
    May 7, 2003
    That is a called a bypass test pipe, it isn't a cat.
    Please replace your cats. Without them, you dump huge amounts of crap in the air for little to no performance gain. While I am not a tree hugger, it makes no sense to create large amounts of pollution for no performance gain.
  10. RavenTai
    RavenTai
    6,048
    38
    Nov 16, 2003
    Dixie co. Florida
    the cats at least on a 96 are already a high flow desighn, kind of liek a window screen extruded, you can see right through them,
  11. Walking Eagle
    Walking Eagle
    3,225
    31
    Sep 6, 2003
    Tulsa, OK
    X2...
    Magnaflow has high flow spun cats, and so does someone else. They tuck up nice cause they're small. If you're OBDII, with two O2 sensors, one before the cat, and one after, it will throw error codes without a cat. I figure keeping the cat keeps me legal, doesn't hurt performance (some tests show taking out the cat hurts performance on OBDII cars), and it doesn't give the eviro-nazi's any amunition. One car vs. one powerplant, the car isn't going to make much difference in the overall scope of things. It will make a difference when treehugggers see you out on the trail with no cats and they have one more thing to hit us with.
