I've had a shake upon putting the truck in to 1st or reverse gear and starting off since as long as I can remember (30+ years). Sometimes the shake is more violent and sometimes less and sometimes not there at all but it always comes back. I also sometimes get a clunking noise at times from somewhere....some shifting part but it does not seem to me the driveshaft or diff since it happens when I am going in reverse and brake the truck to then shift into 1st. Motor or tranny shifting about perhaps? I've written a bit about this in the past if it sounds familiar to anyone. My front end has also taken some hits on it and I have a slightly bent frame and had some pretty twisted up rear motor mounts. I have replaced those with new rubber donuts and bolts (though the frame is still twisted slightly right where the mounts are). I thought this condition might be from clutch judder but after adjusting those 3 fingers on the pressure plate nothing had changed. A couple weeks ago I thought to try torquing down some more on those rear motor mounts. I had them torqued to what appeared to me the proper degree...that is, to where the cotter pin could fit through the hole in the bolt and secure the castle nut. Well, I have since torqued them down a lot more, squeezing the rubber donuts quite a bit, and rendering the cotter pin useless as the castle nut is quite a bit higher up on the bolt. So in theory the tranny and motor are much more tightly bolted down. Now when I start out, though my shaking and shuddering has not completely disappeared, it is greatly improved and sometimes non-existant. Perhaps since my frame has suffered some damage asking this question is a moot point but what should I make of the above info? I can't quite figure the proper tightening of these rear motor mounts and how the "proper" torquing, where the castle nut would be secured by the cotter pin, could firmly secure the motor/tranny. In my case, it seems to have allowed too much movement. How do other people tighten these?
I have included some pics of how twisted the bolts in the mounts HAD been and then two pics with new rubber donuts and pins. I'll have to take some pics of how they are now. I guess one of the other questions buried in this is what might be my next steps to completely get rid of this shaking?
Thanks all, once again. Humbly, Sproggy.
