Question on Reel Steel Soft Top Bow Kit for OEM (1 Viewer)
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
I am replacing the Bestop supertop with an OEM top from Trollhole.
I got the bow set from Reel Steal. They don't provide any instructions
The bows are pretty straightforward. I had to make some modifications to make it work, but pretty easy to figure out
The front window channel looks like it should go on top of the window like the Best Top window channel.
As you all know, that channel is not flight there is a ben in the middle angles down to both sides
The Reel Steel window channel is flat. From pics of OEM tops looks like it should go on top of the window.
Hate to muck it up. Messed up clear coating one of my half doors and had to sand down to bare metal and start again.
It seems obvious, but then . . . . . . . . . . I have been there before :)
Romer
Moderator
Thanks, That is what I thought. The guide isn't bent to fit so I'll do it
It's a 77, but a previous PO rebuilt it using an older windshield like the one in the picture
Just wanted to be sure
