The PO put a 3 on the floor in from a 3 on the tree. If I am right I no longer need the FD knob or the engage lever correct? Both of those were for the old vacuum system right?
The new trans has 3 levers shift, Pto, and 4WD range that is all I need right?
One more thing the old trans had the overdrive unit and behind that a drum emer brake. The PO only installed one side of the emer brake on the back of the trans so there is no emer brake
I have the previous trans with the complete brake it looks like if I swap it over I will need a shorter driveshaft---is that correct?
Thanks for the help
Thanks for the help
