question about tail light in 4Runner
Discussion in '95-older Toyota Truck Tech' started by Macondawg, Mar 12, 2004.
  1. Macondawg
    Macondawg
    24
    Apr 4, 2003
    The tail light bulb keeps burning out in my 99 4Runner. I have replaced the bulb 2 times in 2 months. Can it be anything other than bad bulbs? Wife got pulled over by the police last night and is pissed at me. Gonna be a long weekend if I can't get some help!
  2. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    OT question about tail light in 4Runner
    What do the bulbs look like after they burn out??
    If bulb is black and burnt, it indicates a short.
    If the filament is broken, it could be the bulbs.
    hope this helps
  3. turbocruiser
    turbocruiser SILVER Star
    3,562
    26
    Dec 24, 2003
    If you have an aftermarket added in trailering harness, it could be that the way that they spliced the wires in are shorting out and blowing out bulbs. Other than that, the diagnostic advice that eduardo gave excellently helps figure out what is wrong. HTH.
  4. landtank
    landtank SILVER Star
    19,064
    1,257
    Mar 27, 2003
    Groveland MA
    My wifes 96 4Runner kept bowing the fuse for the tail lights. Turned out that at the port when they installed the hitch harness they ran it through the floor under the carpet trim piece that goes along the back. The idiot didn't insulate the wire just pulled up a platic piece and let the harness rest against the body. Well 6 years later it chafed through and started shorting out. That whole mess in on the PS rear behind the side panel. Thing was it was very intermittent and would sometimes last for weeks. She did get pulled over as there was nothing lit back there but didn't get a ticket.
    Best of luck to ya.
  5. Beowulf
    Beowulf
    12,529
    54
    Mar 27, 2003
    Somewhere in the foothills...
    Re:OT question about tail light in 4Runner
    Exactly the way my '97 Cruiser was wired at the port so things didn't improve between the 4Runner and the Cruiser and between 96 and 97.
    -B-
  6. Jim_Chow
    Jim_Chow
    2,479
    8
    Apr 28, 2003
    Turquoise Trail, N NM
    [quote author=Beowulf link=board=2;threadid=13004;start=msg120620#msg120620 date=1079196297]
    -B-
    [/quote]
    Wasn't there a recall on the '98-99 100's having to do with a faulty trailer harness?
  7. Lars
    Lars
    658
    1
    Apr 17, 2003
    I'm dealing with the same thing on my 2000 4runner. Drivers side tail light keeps burning out.
  8. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,057
    528
    Dec 13, 2002
    Knee deep in hookers and gin
    A couple of things that can blow out bulbs frequently are subwoofers and overcharging systems. If you burned out two recently, I would first suspect the second bulb, then the voltage regulator unless your wife listens to rap at a bizzilion decibles.
