I had previously asked about this problem without resolution, but now I have better possible handle on what is going on. So, here is the scenario... Miss Scarlet purrs like a kitten except when her tank gets down to about a couple of gallons. Then the engine will not run under load. It will start fine, no backfiring and idle perfectly but soon as I try to accelerate it shows classic symptoms of fuel starvation or water in the gas. Both times this has happened I've added HEAT and filled the tank. I let is sit overnight and everything is resolved.
After talking this over with a gear head friend, we're thinking that I've got sediment or water in the tank. I'm sure the tank has never been drained. So, what are your thoughts?
I looked under Miss Scarlet's dress and found what appears to be a large drain plug on the driver's side. It has a square 1/2" fitting. My Haines manual only shows a generic illustration of the gas tank. So, is this the drain plug? If it is, do you have any tips for removing it? Would also appreciate any tips on flushing out the tank after it is drained.
