How much Por-15 is needed to put a few coats on a 40 frame? I would hate to buy a gallon when I only need a quart?
Jake
Jake
Morse_FJ40 said:I am almost done painting my frame with POR-15, I have been using this product for 4 or 5 years now and love it!!! Here is a tip when using it, get some sheet metal screws the ones with the rubber and metal washers. Drill those into the top of the can of POR-15, 180 degrees from each other, at the outer edge of the can. 1 screw is for pouring out of, and the 2nd is for air flow. This will make the can last a lot longer than opening and closing the lid.
I have been brushing it on the frame but am waiting for my new undercoating gun to spray inside the frame rails.
I will show you some pics.
later
Ryan
coiled40gary said:I've used quite a bit of POR-15 with mixed results. Works well if the surface is clean an rough, and no other coatings under it. Spent quite awhile on the phone with the factory about 7 or 8 years ago. If you sweat while you work, be very careful not to let a drip of sweat fall in the paint can. A POR-15 engineer told me that. If you over coat with the POR-15 Chassis Black, the final finish, glossy or flat is effected by how much drying the POR-15 did before applying the over coat.
One big concern from reading this thread, unless things have changed, atomizing POR-15 is very dangerous, and requires a full chem suit. Back then, POR-15 was working on a sprayer to get into hard to reach places like door and frame rails for rust protecting, but this sprayer was not going to atomize. If you use a gun on an air compressor, I think this does atomize.
I used POR-15 on the inside of my frame, just dabbed it in with a brush, and Durabak on the outside of the frame. Durabak sticks to anything very well with little prep, and has rubber bits in it to dampen the noise from gravel coming off the tires on gravel roads. Durabak'd the inside and underside of my tub too. Red inside, and black under side, took a gallon each side, rolled (stipple roller) and brushed it on
gary
Fearnofish! said:Ryan,
I want to do the same thing but the inside of my frame rails ar DIRTY. How did you clean yours out?
foxfab said:My experience with POR15 is that you should run away as fast as you can from it. The stuff has never done what it claims even with the proper prep work. Find another product that works or save your $$$>
