Hi guys I just wanted to share a mod I have done recently on my HDJ81. This is a quick and dirty guide.
this is a retrofit true hid with fully adjustable beam. you will need to bake your headlights to separate your lens. The retrofit consists of two kits put together more detailed parts listed below. the two kits that make up the quad projector is
"Bi-xenon: Matchbox Stage III" and "Retro-Quik: Spyder/Spec-D Lights" you will also need 2x
MotoControl Bixenon: H4/9003" to control the actuators for hi-beam.
Parts needed
Spyder Projector (spec-d) housing (use google to find where to buy)
I sourced all my hid parts from "theretrofitsource"
MATCHBOX-STG3-R
1
Projectors
2 x Bi-xenon: Morimoto Matchbox 2.0 $0.00
MATCHBOX-S
Shrouds
2 x Micro Gatling $0.00
MICROGAT
Ballasts
2 x Morimoto XB35 (35W) $0.00
XB-BALLAST-35
Ballast Igniters (Required)
2 x Morimoto XB Igniter (AMP) $0.00
IGNITER-AMP
Bulbs
2 x H1: 3Five 6000K $0.00
H-ONE-6K
Wire Harness
1 x MotoControl Bixenon: H4/9003 $0.00
MCBX-H4
XB LED Halos
2 x 60mm White $40.00
LEDRING-60W
Sealant
1 x OCI Butyl Rubber Glue $10.00
OCIGLUE
MCBX-H4
1
RETROQUIK-SPYDER-R
1
Projectors
2 x Morimoto Mini H1 6.0 (LHD) $0.00
MH16-LH
Hardware
2 x Spyder/Spec-D Hardware $0.00
HARDWARE-SPYDER
Ballasts
2 x Morimoto XB35 (35W) $80.00
XB-BALLAST-35
Ballast Igniters (Required w/ Ballasts)
2 x Morimoto XB Igniter (AMP) $30.00
IGNITER-AMP
Bulbs
2 x H1: 3Five 6000K $25.00
H-ONE-6K
Re-sealing Glue
OCIGLUE
Dremel EZ Lock Starter Kit
DREMEL-EZLOCK-STARTERKIT
1
JB Weld Epoxy
JBWELD-R
1
Product
1 x JBWeld Steel Stik $0.00
JBWELD-STIK
JB Weld Epoxy
JBWELD-R
1
Product
1 x JBWeld Quik Weld (Pro Size) $15.00
JBWELD-PRO
Step 1
once you get your kit bench test it make sure everything works. for the quad projector please note that the motocontrol box will one will be used for the left and the other will be used for the right side.
STEP 2
separate your lens housing
7 minutes in an oven at 265 degrees Fahrenheit to open
Step 3
fit the spyder spec d brackets in to the morimoto projector and mount into the housing this is a direct bolt on using the adjustable screws to aim the headlight more detailed guide here: http://www.theretrofitsource.com/diy-installation-guides/specd-guide.html
Step 4 (The Hard Part) - Matchbox Projectors
now that the one side is mounted we can move on to the other bulb where the high beam light used to be.
this other part requires some cutting and drilling to fit. I ended up using the reflector to get the Matchbox projectors to mount. for the reflector i basically used a large step bit and drilled the reflector out so I can bolt the projector and sandwich it in place with the provided silicone washers. I then used jb weld to glue it in place. I also had to make new ajusting screws for the other side as the weight of the projector keeps popping out the factory screws out of the ball socket. I went to the hardware store and bought the same length bolts and doubled nutted one end and ground the head off to fit behind the reflector. before glueing in the projector make sure it is level and strait!!!
more detailed guide of Matchbox Projector
http://www.theretrofitsource.com/diy-installation-guides/morimoto-matchbox-2-0-guide.html
I also cut a spot to get a flat head screwdriver to aim the beam
once mounted should look like this
Step 5 Hook it up and test test test!!!!
test the high beam actuators at least 30 times before sealing up the lens
sealed it up and tested the halos and daemon eyes additional bling
as you can see in this pic minor trimming was needed to fit the projector and the shroud (far right projector) the left proector did not require a shroud to fit evenly.
step 6 seal it up and install and adjust aim
I basically aimed each individual beam using the adjusting screws on the back. i used this method of aiming the beam
here it is installed
here is my light beam pattern
Parts needed
MATCHBOX-STG3-R
1
Projectors
MATCHBOX-S
Shrouds
MICROGAT
Ballasts
XB-BALLAST-35
IGNITER-AMP
Bulbs
H-ONE-6K
Wire Harness
MCBX-H4
XB LED Halos
LEDRING-60W
Sealant
OCIGLUE
MCBX-H4
1
RETROQUIK-SPYDER-R
1
Projectors
MH16-LH
Hardware
HARDWARE-SPYDER
Ballasts
XB-BALLAST-35
IGNITER-AMP
Bulbs
H-ONE-6K
Re-sealing Glue
OCIGLUE
1
JB Weld Epoxy
JBWELD-R
1
Product
JBWELD-STIK
JB Weld Epoxy
JBWELD-R
1
Product
JBWELD-PRO
Step 1
STEP 2
Step 3
