PWR button
Kampala
Is there any negative impact of driving with the PWR button on all the time? Especially impact on transmission life.
the button is basically there for show, i feel almost no difference with it on or off
Really??? The button makes a whole world of difference to me. The transmission shifts too quickly and there is no fun when PWR is off. I actually feel too much power with PWR on.
I have always been reluctant to use it because mechanic says it burns transmission.
I mean technically the transmission will work a little harder and your gas mileage is going to be slightly worse but in the long run I highly doubt it affects anything. Sometimes I run with it on, sometimes I forget its on for weeks at a time, sometimes i dont have it on. I wouldnt be concerned.
it turns my cruiser into a drag car. Love me some power button ;)
The Power button changes the shift points further up the rpm band, that's all. I suppose if you normally accelerate with the skinny pedal all the way to the floor you may not notice any difference.
Same. I’ve tried it a few times and noticed no perceivable difference. The switch definitely works as the induction the dash illuminates. 🤷‍♂️
I notice the later shifts, especially when pulling into a tight gap in moving traffic and have to get on the gas.
If you're worried about this sort of thing, get a bluetooth OBDII scanner and something like the Torque app for your phone (both are reasonably priced). You can customize a gauge screen, including your trans temps. I mainly use it when towing to be sure I'm not overheating my trans, or for scanning error codes.
