Puttin in an Add-a-Leaf
Discussion in '60-Series Wagons' started by mtb_rider, Feb 21, 2007.
  1. mtb_rider
    mtb_rider
    881
    2
    Feb 17, 2007
    Wilsonville, OR
    So, fixin to put my lift on in the next day or two. To anyone out there who as installed an add-a-leaf in an FJ, about how long should it take. I was crawlin around under there today lookin at what it will take, and tryin to plan for the install, time wise. I am an experienced mechanic (a boat mechanic actually), and have air tools and all that, but will be doing the job on the ground on the jack stands. And while I'm at it, anyone have pics of an FJ with a 3-4" lift with 33's on it? Preferrably 12.5's, but any 33 will do. Would like to get an idea of what she'll look like after this weekend. Thanks.
  2. lovetoski
    lovetoski SILVER Star
    4,534
    203
    Jul 13, 2003
    2 hours per side. (I've done it a few times, I've not gotten any quicker.) A few pointers (hope they're not insulting)
    • Have the jackstands under the frame, not the axle.
    • Let the axle/spring hang free
    • Leave the spring attached to the frame.
    • Use a jack to lift the axle up off the springs while you work on them.
    • Put a c-clamp right next to the spring center pin so you can easily remove the pin.
    • If the spring center pin is trashed, a fine thread cap head bolt (3/8"??) makes a perfect replacement.
    • Position c-clamps on the leafs just one leaf above where you will put your AAL. Position them so that the AAL will fit.
    • Use a long bolt from the bottom to keep the leafs aligned while you c-clamp them back together.
    • When they are clamped together, and aligned properly, remove the long bolt from the bottom, and install the spring pin from the top.
    • Getting the axle to line back up on the head of the spring pin is the most irritating part.
  3. philos1
    philos1
    1,593
    Feb 8, 2005
    the valley, yeah that one
    pretty easy, a few hours per axle.
    soak EVERYTHING in PB blaster for a few days.
    taking the spring packs apart is a bit of a PITA, but do-able with a chisel and some vice grips, just bend em back when you're done.
    got new bushings, u-bolts, spring pins, shackles, etc? you may need em.
    have fun!
  4. philos1
    philos1
    1,593
    Feb 8, 2005
    Oh, and double up on c-clamps, they sometimes break in a dangerous manner.
  5. mtb_rider
    mtb_rider
    881
    2
    Feb 17, 2007
    Wilsonville, OR
    Not insulting, and I'm a boat wrench. Believe me, you have to ask the stupid questions, and a lot of times you DO get a stupid answer. You can get the spring pack brackets un-bent, then re-bent without any problems with the spring attached to the frame?
  6. brokenparts
    brokenparts
    4,041
    86
    Apr 4, 2006
    Hillsboro, OR
    yep, two clamps... this happened while installing my aals.
    [​IMG]
    Dont forget some PB blaster on the bolts the night before too! :cheers:
  7. agent orange
    agent orange
    2,227
    7
    Jul 8, 2005
    New Kent, VA
    Wow, that pic brings back memories for me. I had to flip the center pins on my rear springs, they were in upside down from the factory. I did it on the truck and holy crap those short bottom leaves got some distance flying around the shop after plinking off the ground between my legs!!!
  8. lovetoski
    4,534
    203
    Jul 13, 2003
    Yep.
    Key is to take the load off the spring...as in have the axle supported on it's own. The longest leaf on the spring will carry most of the load between the fixed eye and the shackle. You use the c-clamps to force the other leafs to fit to the longest leaf.
