Pushrod cover wont come off
Discussion in '60-Series Wagons' started by radd5, Mar 3, 2007.
  1. radd5
    radd5
    39
    Mar 18, 2004
    Northern Virginia/Fairfax
    I have a leak from the pushrod cover. I took off the 10 bolds, 2 nuts, distributor, and oil filter. The damn cover wont come off...it wont even budge...it is stuck on there.
    It doesn't appear there is a gasket between the cover and block (at least not visible).
    Do I need to pry the thing off. If so any suggestions on how?
  2. Okie_dave
    Okie_dave SILVER Star
    807
    16
    Jan 2, 2005
    Tulsa, OK
    Yeah - pry carefully. It usually has a cork gasket and they get baked on. Take a putty knife and tap it with a hammer to get it started. Or a screwdriver but you can do more damage that way.
  3. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,454
    1,919
    Feb 17, 2002
    Las Vegas
    putty knife in a lot of places. repeat.. lots of places... pry gently..
  4. ellington12
    ellington12
    391
    1
    Feb 12, 2005
    bay area
    the gasket should be cork. in that case, as others have said, thin putty knife and patience. they also make a gasket remover spray that softens the gasket which helps a little...you can find this at any of your chain auto parts stores.
    if it looks like there is no gasket, then thin putty knives (plural) and patience.
    they'll come off...but you may have to curse a bit.
